Jason,
    Is it possible to have 3 UART on WICED? The API defined only 2 inside, does it mean that we only can support 2 UART interface?
    For the hardware connection, I am confirming with USI engineer. This is the request from Haier. Haier plan to connect the NFC module to WICED by one more UART.
Absolutely. You have full source code and control of your platform, and you
can add as many or few peripherals (including UARTs) as needed.
