03:20 PM
Mar 13, 2013
03:20 PM
[WICED-SDK-2.2.1]I need to know info about the AP my device is connected to, how do I get this?
Labels
SPI
- back
- connected
- determines
- find
- format
- handler
- information
- investigate
- parsing
- probe
- responses
- result
- scan
- security
- setting
- structure
- wl_bss_info_t
03:23 PM
Mar 13, 2013
03:23 PM
An API to get this info will be added in the next SDK release, until then, please read the information & patch in the source code provided in the attached file.
03:06 PM
Mar 24, 2013
03:06 PM
Thanks for the code snippets to retreive the AP details of the connected AP. However, there seems to be a small bug in returned results.Ive updated this code to translate the bss_info_t to ap_info_t just as in the scan_result_handler. But when I do this in the wiced_wifi_get_ap_info() function I get the wrong security type. Ive connected to a WPA2_AES network, but the functions returns that it is WEP_PSK. The scan results, using the same translation code, are OK.
03:07 PM
Mar 24, 2013
03:07 PM
Hmm.. Ill need to investigate this further. The scan result handler determines the security setting by parsing the IEs in the probe responses however I am not sure if all that information is kept in the same format in the wl_bss_info_t structure.Ill look into it and get back to you.
