I am running WICED code from external flash using the XIP support, however I am unable to debug using openOCD with Eclipse.
I usually use the 3333 for GDB port. Is there instructions on how to setup debugging from external flash ?
SPI
Wi-Fi Direct
WICED Studio
Please check if the solution in this forum post helps Debugging the BCM943362WCD4_EVB
Ok. Another question, regarding running from external flash using the XIP string, does the compilation output show how much of flash is being used for each module being linked ? When I enable the XIP, the compilation output still shows 0 for all modules under "flash" although I know it is running from external flash.
In WICED SDK 6.1, the flash consumed is shown in the build console when XIP is enabled.
ok thanks., I will try SDK 6.1 then as currently 6.1.1 is not showing how much is consumed from xFlash.
