When trying to compile WICED 3.5.2 on Ubuntu 16.06 Linux 64 bit system I get:
WICED/platform/GCC/math_newlib.c:30:5: internal compiler error: Illegal instruction
x -= ( (int) ( x / ( 2 * PI ) ) ) * 2 * PI;
More output below.
br1@void:~/wiced/WICED-SDK-3.5.2$ ./make snip.scan-BCM94343WWCD1 VERBOSE=1 JOBS=1
MAKEFILE MAKECMDGOALS=snip.scan-BCM94343WWCD1 OTA2_SUPPORT is disabled
./tools/common/Linux64/mkdir -p build/snip.scan-BCM94343WWCD1/binary build/snip.scan-BCM94343WWCD1/modules build/snip.scan-BCM94343WWCD1/libraries build/snip.scan-BCM94343WWCD1/resources
"./tools/common/Linux64/make" -r -j1 -f ./tools/makefiles/wiced_elf.mk snip.scan-BCM94343WWCD1
make[1]: Entering directory `/home/br1/wiced/WICED-SDK-3.5.2'
echo Building Bootloader
Building Bootloader
"./tools/common/Linux64/make" -r -f ./Makefile waf.bootloader-NoOS-BCM94343WWCD1 -Ibuild/snip.scan-BCM94343WWCD1 SFLASH= EXTERNAL_WICED_GLOBAL_DEFINES= SUB_BUILD=bootloader
MAKEFILE MAKECMDGOALS=waf.bootloader-NoOS-BCM94343WWCD1 OTA2_SUPPORT is disabled
make[2]: Entering directory `/home/br1/wiced/WICED-SDK-3.5.2'
./tools/common/Linux64/mkdir -p build/waf.bootloader-NoOS-BCM94343WWCD1/binary build/waf.bootloader-NoOS-BCM94343WWCD1/modules build/waf.bootloader-NoOS-BCM94343WWCD1/libraries build/waf.bootloader-NoOS-BCM94343WWCD1/resources
"./tools/common/Linux64/make" -r -f ./tools/makefiles/wiced_elf.mk waf.bootloader-NoOS-BCM94343WWCD1
make[3]: Entering directory `/home/br1/wiced/WICED-SDK-3.5.2'
"./tools/ARM_GNU/bin/Linux64/arm-none-eabi-gcc" -isystem ./tools/ARM_GNU/bin/Linux64/../../include -isystem ./tools/ARM_GNU/bin/Linux64/../../lib/include -isystem ./tools/ARM_GNU/bin/Linux64/../../lib/include-fixed @build/waf.bootloader-NoOS-BCM94343WWCD1/libraries/common_GCC.c_opts -o build/waf.bootloader-NoOS-BCM94343WWCD1/Modules/WICED/platform/GCC/math_newlib.o WICED/platform/GCC/math_newlib.c
WICED/platform/GCC/math_newlib.c: In function 'sin':
Please submit a full bug report,
with preprocessed source if appropriate.
See <http://gcc.gnu.org/bugs.html> for instructions.
make[3]: *** [build/waf.bootloader-NoOS-BCM94343WWCD1/Modules/WICED/platform/GCC/math_newlib.o] Error 1
make[3]: Leaving directory `/home/br1/wiced/WICED-SDK-3.5.2'
make[2]: *** [main_app] Error 2
make[2]: Leaving directory `/home/br1/wiced/WICED-SDK-3.5.2'
make[1]: *** [bootloader] Error 2
make[1]: Leaving directory `/home/br1/wiced/WICED-SDK-3.5.2'
make: *** [main_app] Error 2
