Under WICED Studio 5.0, several users has experienced problems during the install which are related to white space in temp folder name.
Example: C:\Users\John Doe\AppData\Local\Temp\
The workaround here is to change the location of temp folder as shown below :
- Create a folder such as c:\temp (without white space)
- Go to Control Panel -> System -> Advanced System Settings -> Environment Variables
- Change the ‘TEMP’ and ‘TMP’ variables to c:\temp
- Note: Requires admin rights along with write permission to the TEMP and TMP folders
Log off and log on, then install.
This issue will be resolved in the next release of WICED Studio.
Is there a release date for corrected WICED Studio?
WICED Studio 5.1 will be released sometime in the beginning of July.
Just a note regarding the install. After installing 5.0 there were no shortcuts created. I can go into the folder and click on eclipse.exe, but there was no desktop shortcut and nothing created in the Start>All Programs.>Cypress folder.
Installation now works correctly. Thanx for the quick hint1
Regards, Bob
So this issue is *not* resolved in sdk-6.2?
