BeDe_2507241
Level 4
Level 4
First like received
How the stack size of the main thread, i.e., void application_start( )  can be increased?
GauravS_31
10 questions asked 250 solutions authored 250 sign-ins
You can use the macro WICED_DEFAULT_APPLICATION_STACK_SIZE in wiced_defaults.h to adjust the application stack size. This is basically used in tx_thread_create() in case of ThreadX to define the stack size of application_thread_main which calls application_start().
GauravS_31
