HaTr_4568521
First like given
I've programmed the kit as an AP and trying to transmit the data over wireless medium. The data rate I'm looking for is not more than 4 Mbps, however, the link shows 40 kbps only. Detailed problem statement is explained in attached PDF. Kindly help me fix this.
Please let me know if more information is required on the same to fix the issue!
VinayakS_26
100 replies posted 50 replies posted 25 replies posted
What is the version of Wiced that is being used here?
Could you provide the values of following macros in your application
TX_PACKET_POOL_SIZE,  RX_PACKET_POOL_SIZE, GPBUF_POOL_TX_SIZE, PBUF_POOL_RX_SIZE.
VinayakS_26
VinayakS_26
VinayakS_26
