lefeno
First like received 10 sign-ins 5 replies posted
I am using CYW54907  dev board, WICED SDK 6.6 with default Netx Duo. I want to ask if the wiced sdk has supported for dhcpv6 request, dnsv6 and pingv6 yet.
Apparently, I don't see any implementation on creating and requesting dhcpv6 on SDK. I did capture packet from the board with the Wireshark, but don't see any dhcpv6 packets. And without dhcpv6 support, i cant get dnsv6 ip address too.
I don't even see Router Solicitation packet, Neighbor Solicitation from my board too. Does the sdk currently only generate IPv6 from Router Advertisement packet, and doesn't care about duplicated addresses?
AditiB_81
5 questions asked 250 replies posted 250 sign-ins
I'll confirm with the internal team and will revert back to you.
Aditi
Hi, did you ask the internal team?
If you need such long time to confirm with your internal team, that is a problem.
lefeno
Hi, did you ask the internal team @AditiB_81
AditiB_81
Apologies for the delay. Ping for ipv6 is not implemented in WICED. You can check the following snapshot.
Location - WICED-Studio-6.6\43xxx_Wi-Fi\WICED\network\NetX_Duo\WICED\tcpip.c
Aditi
But you only replied part of the question.
What about dhcpv6 request and dnsv6?
