harelTur
25 sign-ins 10 replies posted 10 questions asked
Hi
I try to init I2c and I dont see any signal of clock of I2c
My code :
static const wiced_i2c_device_t BARO_I2C =
.port = BARO_I2C_PORT,
.address = BARO_I2C_ADDRESS,
.address_width = I2C_ADDRESS_WIDTH_7BIT,
.flags = 0,
.speed_mode = I2C_STANDARD_SPEED_MODE,
static void BARO_InitHw(void)
wiced_result_t res;
/* Initialize I2C */
if ( wiced_i2c_init( &BARO_I2C ) != WICED_SUCCESS )
BARO_LOG_ERROR_MSG("BARO I2C init failed\n");
else
BARO_LOG_DEBUG_MSG("BARO HW : I2C init success \n");
/* Probe I2C bus for temperature sensor */
if( wiced_i2c_probe_device( &BARO_I2C, 3 ) != WICED_TRUE )
WPRINT_APP_INFO( ( "Failed to connect to baro device; addr 0x%x\n", BARO_I2C.address ) );
return;
else
WPRINT_APP_INFO( ( "success to connect to temperature device;\n" ) );
My loger print :
14:49:47.701 [RX] - 0125 00:01:26.962 [#ERROR#|BARO | 299] Couldn't read Barometer. res=2, id=0x1C
When my HW connection:
*I use  EVB: Sterling EWB development KIT of Cypress
#define BARO_INT_GPIO /*WICED_GPIO_PC4 */ WICED_GPIO_PB12
#define BARO_I2C_SCL WICED_GPIO_PB6
#define BARO_I2C_SDA WICED_GPIO_PB7
#define BARO_I2C_PORT WICED_I2C_1
#define BARO_I2C_ADDRESS BAROMETER_ID
SCL - PB6
SDA - PB7
I don't see any sugnal of clock
harelTur
This is my log :
Failed to connect to baro device; addr 0xb1
DheerajPK_41
750 replies posted 500 likes received 500 replies posted
Sorry we have missed your query.
May I know which chip are you using? Is it CYW20706?
-Dheeraj
