Hi ,
Let us introduce my self. I am Srinivas working as TL.
I would like to purchase IOT( Internet of things) BCM943362WCD4 from board-com.
Kindly let me know following details
1) Technical ( drivers and application ) support how good is it ?
2) Any other tools(hardware/software) are required for start working on BCM943362WCD4 Evaluation module.
Srinivas K
- avnet
In addition to the Help Blogs and discussions found here on the forum, most of our application/driver support is intrinsic to the WICED Wi-Fi SDK found here: WICED Wi-Fi Documents & Downloads
Specifically, take a look at the following directories:
/demo
Complete application demos: Appliance, BT SmartBridge & Temp Control
/snip
Functional “snips” which can be used as building blocks for full applications
30+ snips included in SDK 3.1.x
/test
Applications used for manufacturing, regulatory and bench testing
/waf (WICED Application Framework)
Includes all necessary software elements (Bootloader, OTA upgrade, serial flash access, etc.)
/wwd (WICED Wi-Fi Driver)
Low level WICED driver for customers that want to write their own Wi-Fi applications within their own framework
Support is limited
Avnet covers your region and also has the board in stock: Broadcom BCM943362WCD4, - Avnet Express
From our Distributors page here, you have a local/regional Avnet contact as well that you can leverage for support:
No. 402, Fourth Floor, Tower-B, RMZ Infinity
No. 3, Old Madras Road,
Bangalore 560 016
India
Tel : +91-80-40604000+91-80-40604000
Fax : +91-80-40604060
Chandran Ramamurthy
/demo
/snip
/test
Support is limited
Bangalore 560 016
India
Chandran Ramamurthy
