I am trying to access wiced_rtos_create_thread function from wiced bootloader code ota2_bootloader.c I included necessary header files. But it throwing an error like \WICED\43xxx_Wi-Fi/apps/waf/ota2_bootloader/./ota2_bootloader.c:598: undefined reference
SuHR_4662741
\WICED\43xxx_Wi-Fi/apps/waf/ota2_bootloader/./ota2_bootloader.c:598: undefined reference to `wiced_rtos_create_thread'
void IPC_BL_create_thread (void)
   wiced_rtos_create_thread(&IPCBLthread, IPC_BL_THREAD_PRIORITY, "IPC_BL", IPC_thread_BL,
IPC_BL_STACK_SIZE, NULL);
   return;
What may be the issue?
Can we acess wiced rtos threadx api from ota bootloader section.
Please suggest.
Aditi_B
500 replies posted 5 questions asked 250 replies posted
Which version of WICED are you using? Can you attach the application code that you're using to get a better idea of the problem?
Also, provide a snapshot of the error logs/build logs that you're getting while compiling the application?
Aditi
