- Email to a Friend
We saw a major issue on calling wiced_tcp_disconnect with tis context that will lead to system crash.. This can be very easily reproduced on the demo code snip.https_client sample in the SDK.
Aaron Lee
SDK 3.x
Web Services
- Email to a Friend
This has been root caused to a bug in gcc producing an invalid instruction sequence under some circumstances.
Recommended fix is to modify the wiced_toolchain_ARM_GNU.mk and change line 102/103 from "-O3" to "-Os"
- Email to a Friend
Can you please do a test for me - can you build and run in debug mode and see if the issue still happens or not? add "-debug" to the makefile command
- Email to a Friend
Enabling the debug on snip.https_client will help but still crashes if you loop the https get. It will crash after few loop.
Aaron Lee
Sent from my iPhone
- Email to a Friend
- Email to a Friend
Was this fixed in 3.1.1? If not what parameter (and line number if possible) needs to fixed in:
COMPILER_SPECIFIC_RELEASE_CFLAGS?
- Email to a Friend
Yes this has been fixed in SDK 3.1.1. No changes required
- Email to a Friend
Hi
Is this problem solved in SDK 3.1.1?
I had similar problem in SDK 3.1.1. Web access seem not to be valid.
so if connection is done , and try get another page then it takes long time.
Test env : SDK 3.1.1 + FreeRTOS+LwIP
I changed OS from FreeRTOS to ThreadX, Web access is working well and no problem occured.
So I thought that this is driven from
- memory usage(management ) difference is from each OS, so some of malloc fail happen.
- socket count management in http server
- socket connection timeout
Test env : SDK 3.1.1 + ThreadX+NetX
With changing to ThreadX, all works fine.
Additionally, ThreadX has some other issues in different function.
TKS
- Email to a Friend
Hi Alex,
We use SDK 3.1.1 + ThreadX+NetX setup and so far is working alright. I suggest to post another thread specific for 3.1.1 with your setup and see how Broadcom response.
- Email to a Friend
Hi aaron
it is good to hear that you are all right.
With 4390, I am doing test with 4390 module and you can see our module's web.
It is working well with ThreadX
It is 4390's EVB and our web in module.
We are planing our own module with good antenna design.
TKS
