How to use jlink debug STM32F4xx on Wiced Studio?
lx58
5 sign-ins First solution authored First reply posted
I have a STM32F412+CYW43438 EVB to develop a ioT device.
I try to follow all debug configuration settings on forum but I get a problem here.
I set breakpoint at my application_start in Startup option but actually start at WICED/platform/ARM_CM4/crt0_GCC.c _start
Have someone to help this issue?
lx58
Hi Rakesh_BG,
Very appreciated your response, it work now.
Thanks a lot.
lx58
Rakesh_BG
50 solutions authored 100 replies posted 100 sign-ins
Hi @lx58 ,
You can refer to the document attached for the steps to debug on Wiced Studio .
Document gives the steps for 43907 . you can use by making small modifications .
Rakesh B G
lx58
Hi Rakesh_BG,
Thanks a lot.
lx58
lx58
I got a problem now. I can't step into my application_start(). Even I modify Startup->Set breakpoint at: application_start. Have someone can help or point out what wrong is for me?
lx58
I try to modify Startup settings as below and debugging will start at _start in crt0_GCC.c
Press several F6 then tracing jump into application_start.
