Sep 11, 2018
12:34 AM
Sep 11, 2018
12:34 AM
According to BLE spec it should be possible for master and slave to update the connection parameters after entering the connection state (see Bluetooth Spec 4.1 Vol6 - 5.1.7 Connection Parameters Request Procedure).
The example "snip/bluetooth/serial_gatt_service" acts as BLE peripheral/slave and uses the L2CAP function wiced_bt_l2cap_update_ble_conn_params() to change the connection interval to save power.
Can we use the same function to update the connection parameters when acting as central?
best regards,
Gregor
04:24 AM
Sep 11, 2018
04:24 AM
Hi Gregor,
You can use the same API ( wiced_bt_l2cap_update_ble_conn_params() ) from Central side as well.
Anjana
