Hi abirjepatil
I tried to run demo.aws_iot.pub_sub.publisher demo code on SDK-3.5.2.
But I got below error:
Joining : LAB
Successfully joined : LAB
Obtaining IP address via DHCP
Network ready IP: 192.168.1.103
Resolving IP address of MQTT broker...
Resolved Broker IP: 52.192.145.107
[MQTT] Opening connection...
[MQTT LIB] : error intializing the mqtt connection setup
After adding debug code, it shows
wiced_tls_init_root_ca_certificates returns -96.
x509_convert_pem_to_der returns -64 because s2 is NULL.
Below print out the content of pointer p:
Obviously, it's incompleted so it returns TROPICSSL_ERR_X509_CERT_INVALID_PEM (-64).
-----BEGIN CERTIFICATE-----
MIIE0zCCA7ugAwIBAgIQGNrRniZ96LtKIVjNzGs7SjANBgkqhkiG9w0BAQUFADCB
yjELMAkGA1UEBhMCVVMxFzAVBgNVBAoTDlZlcmlTaWduLCBJbmMuMR8wHQYDVQQL
ExZWZXJpU2lnbiBUcnVzdCBOZXR3b3JrMTowOAYDVQQLEzEoYykgMjAwNiBWZXJp
U2lnbiwgSW5jLiAtIEZvciBhdXRob3JpemVkIHVzZSBvbmx5MUUwQwYDVQQDEzxW
ZXJpU2lnbiBDbGFzcyAzIFB1YmxpYyBQcmltYXJ5IENlcnRpZmljYXRpb24gQXV0
aG9yaXR5IC0gRzUwHhcNMDYxMTA4MDAwMDAwWhcNMzYwNzE2MjM1OTU5WjCByjEL
MAkGA1UEBhMCVVMxFzAVBgNVBAoTDlZlcmlTaWduLCBJbmMuMR8wHQYDVQQLExZW
ZXJpU2lnbiBUcnVzdCBOZ\0xef\0x80q/\0x09\0x02
Then I print out the content after resource_get_readonly_buffer() call
and got the same data as above.
AWS
- teaser
I figured out the problem: the size_out is 512.
If resource->location != RESOURCE_IN_MEMORY && USES_RESOURCE_FILESYSTEM is defined, the max return size_out is 512.
the size of rootca.cer is bigger than 512.
Any patch available to fix this?
one more thing,
It's wrong to use strlen( (const char*)trusted_ca_certificates):
result = x509_parse_certificate( root_ca_certificates, (const uint8_t*)trusted_ca_certificates, strlen( (const char*)trusted_ca_certificates ) );
You need to make sure trusted_ca_certificates is NULL terminated if you want to use strlen.
In my test, the returned security.ca_cert is not NULL terminated.
Could you tell us, what procedure are you using to load the certificates in your application ?
Since there are two techniques, one is to read from the resource folder and other you can have certificates loaded as character array to variables and use them.
vik86,
The demo.aws_iot.pub_sub.publisher demo code uses reading read from the resource folder.
I think already pointed out the part of problematic code.
I repeat again here:
1) below code is wrong when resource->location != RESOURCE_IN_MEMORY && USES_RESOURCE_FILESYSTEM is defined
resource_get_readonly_buffer( &resources_apps_DIR_aws_iot_DIR_rootca_cer, 0, MQTT_MAX_RESOURCE_SIZE, &size_out, (const void **) &security.ca_cert );
return maximum size_out is 512 which is not big enough for rootCA.
2) You cannot use strlen in below cases because resource_get_readonly_buffer() does not ensure security.ca_cert/security.cert/security.key are NULL terminated. Which means stlrn can return wrong size.
Also apply to x509parse_key().
This has been discussed earlier mkochhal , the certificates needs to be indented with proper "\n" ending
Also sam.lin we are working on optimizing the MQTT library and sample applications. If you are not able to get your sample application work, there are issues with your setup or certificates, we can help with those.
Using the x509 certificate parsing tool does not always solve the certificate indentation or formatting issues... I had to manually tweak the certificate parsing, so that the function x509_convert_pem_to_der() can succeed.
