According to the datasheet, the CYW4343W has a WLAN unit and Bluetooth unit, both having an ARM CM3 processor, RAM and ROM on-chip memory. Also according to the datasheet:
"External patches may be applied to the ROM-based firmware to provide flexibility for bug fixes or feature additions. These patches may be downloaded from the host to the CYW4343W through the UART transports."
However, I can't seem to find any clear documentation on how to apply patches to the ROM-based firmware. Can anyone refer me to any documentation on how this is done?
A bit more context from my end: we have our custom hardware including a Murata 1DX module, which includes the CYW4343W chipset.
Any help would be much appreciated.
Other Technologies General
Have you contacted Murata regarding the patches?
The standard approach is to use Write_RAM commands and write the payload to RAM or flash as per the requirement to download the patch. Some useful links are given below.
https://github.com/Infineon/btsdk-docs/blob/master/docs/BT-SDK/WICED-HCI-Firmware-Download.pdf
https://github.com/Infineon/btsdk-docs/blob/master/docs/BT-SDK/WICED-HCI-Control-Protocol.pdf
I am checking internally, if there is any single document to explain the procedure to apply patches to 4343 specifically.
-Dheeraj.P.K
