Jan 30, 2015
12:25 AM
Jan 30, 2015
12:25 AM
Dear Broadcom team,
I use WiCED-WiFi Sip module from SPIL
I'd like to implement " No Tx Power" because I'll use "Passive scan mode" only.
Used "snip.scan-BCM943362WCD4". I modify source code to implement Passive scan mode and I already check it's passive scan mode. App is very simple which is scan and delay.
BTW, there is tx shoot when start Passive scan as below.
I htink below source code routine make Tx shoot.
"retval = wwd_sdpcm_send_ioctl( SDPCM_SET, (uint32_t) WLC_UP, buffer, 0, WWD_STA_INTERFACE );"
Could you please let me know how to remove this Tx shoot?
Ryan.
