I want to download the Wiced 4.0.1 to develop my product , I find the link:
but I can not download any file from the link.
The response is:"You do not have sufficient privileges for this resource or its parent to perform this action."
Could anyone help me to get Wiced 4.0.1 SDK ?
WICED Studio Wi-Fi Combo
Hi @MilesHsu ,
WICED 4.0.1 is a very old version and is now deprecated. I would suggest you to please use latest WICED SDK versions: https://www.cypress.com/products/wiced-software
Also, you can look at ModusToolbox- https://www.cypress.com/products/modustoolbox
@SheetalJ wrote:
Hi @MilesHsu ,
Is the firmware built with ModusToolbox compatible with WICED?
e.g. For existing WICED users, is it safe to OTA from WICED application firmware to new firmware built with ModusToolbox?
If not, ModusToolbox is not an option for existing WICED users.
I asked this because there is no update for WICED for quite long time.
Even the latest wiced-6.6 was released 1 year ago.
BTW, I think cypress/infineon should at least maintain WICED for bug fixes / security fixes.
Dear @SheetalJ
My product is designed by the old version WICED 4.0.1 in 2016. Now I want to add some features for the product so I need to install WICED 4.0.1.
Could please you provide the SDK WICED 4.0.1 to me?
Hi @MilesHsu ,
As it is a deprecated version, we can't provide the version on community. Please check your Community message inbox.
<<<Is the firmware built with ModusToolbox compatible with WICED?
No. The firmware for ModusToolBox is not compatible with WICED environments. A WICED SDK 6.6.1 is expected soon but I believe the only changes are the new ExpressLogic (NetX and NetXDuo) Libraries to solve the "WRECK IP" vulnerability".
Check the mbedTLS version and FreeRTOS version in WICED, you will find vulnerabilities that needs fix as well.
