- Email to a Friend
I manage to get "access token" through "avs_authorization" in SDK 5.2.
However for the next step, I need "refresh token".
Using redirection form which is "main.html" in the SDK ,seems only generating access token.
The following picture is the access token I got through the redirection form in the SDK but there is no information about
"refresh token" in this form.
Does anyone know how to get refresh token?
Soohwan.
AWS
- Email to a Friend
Hi All,
It's answer about my own question.
Finally I managed to get refresh token, however I spent over one day due to no guide about this.
I didn't notice that access token & refresh token comes together because the webpage's title only indicates "download access token" and the access token string itself is way long.(2KB)
It would be better to change it's title from "access token" to "access token & refresh token" or else with simple guide how to use it respectively.
Soohwan.
- Email to a Friend
Hi All,
Soohwan.
