I am trying to configure WICED to debug the CYW4343W, specifically the Laird Sterling EWB.
Since this is ST based, it seems much of what I have found through searches does not apply.
I am using a SEGGER J-Link. I believe I may have to create a flashloader configuration but I'm not sure where or how to apply this.
I have three options when I go to Debug Configurations
- GDB Hardware Debugging
- GDB OpenOCD Debugging
- GDB SEGGER J-Link Debugging
I am using WICED v6.6
My make target is:
laird.<app_name>-LAIRD_EWB-ThreadX-NetX-SDIO-debug download
Thank you,
-Rocko
Debug
WICED Studio
Wifi+Bluetooth
Wireless MCU
I received a PDF from Cypress via my Laird FAE (cannot post to the thread)
I am now able to use JLink with WICED SDK.
Side note:
This driver seems to have broke the connection between the JLink module and Seggers's J-Link tools but, I am now debugging in WICED and that was the goal.
-Rocko
Rocko,
Here’s a couple options on setting up the debugger that may give some insight:
I use a reference from Priya @ Cypress that was attached to the Community Post, “wiced Debug” @ . https://community.cypress.com/message/152296
There’s a similar document from Murata that has some different settings than recommended in the attached. Reference the Community Post “Wiced Debugging challenges” @ https://community.cypress.com/message/202988
The differences appear to be due to the location of executable code. Reference section 4, “Known Issues/Fixes” in the WICED Release notes @ https://community.cypress.com/docs/DOC-17741
Greg
Hey Rocko,
Just for the clarification on my side, do you want to debug the host(ST based) or the CYW4343W Cypress combo chip?
I want to debug the application on the CYW4343W Cypress combo chip. My understanding is, the MCU on the combo chip is an STM32F412 Cortex M4. This is the only MCU on the Laird Sterling EWB evaluation board.
-Rocko
Hey Rocko,
Yes, Laird Sterling EWB evaluation board has STM32F412 Cortex M4 MCU, but this MCU is not on the combo chip (CYW4343W). Basically, the module on the eval board comes with an integrated STM32F412 MCU with the Cypress CYW4343W chip. You can refer to the block diagram given below:
So, correct me if I am wrong, but I think you want to debug the applications that will be downloaded on the host MCU integrated in the module i.e. STM32F412 and not the Cypress chip cause applications are not running on the Cypress chip.
You can refer to the following space: Laird Connectivity for your reference:
Aditi
Yes, You are correct. I want to debug the applications that will be downloaded on the host MCU integrated in the module i.e. STM32F412 and not the Cypress chip.
Thank you,
-Rocko
Side note:
-Rocko
