How to check the current BLE connection interval
hachc_2137126
While using WICED SDK 3.5.2 with BCM43341 platform as a central role, is there any methodology to get current connection interval of one specific connection?
Also, any callback registration is available for checking/monitoring the incoming request of connection parameter update from peripheral side?
There are no APIs to determine the connection interval of a BLE connection. If the 43341 is used as the central (initiator), then the connection parameters will be that set in the wiced_bt_cfg_settings_t.
There are no events for connection parameter update request.
