default CONFIG_AP_PASSPHRASE was "12345678", change PASSPHRASE to "1234", but config mode AP doesn't work.
How can i do?@
SDK 3.x
Have you tried other passphrase like "23456789"?
It requires at least 8 characters I think.
You can modify the CLIENT_AP_SSID/CLIENT_AP_PASSPHRASE Wi-Fi credentials in the /WICED-SDK-3.3.1/include/default_wifi_config_dct.h header file to match your Wi-Fi access point
There is some additional information here as it pertains to the appliance demo and SDK 2.4.1: Demo of the "Appliance Application" in WICED SDK
Thank you, for your comment and it workable in CLINET mode, but can't work in CONFIG mode.
modify default_wifi_config_dct.h CONFIG_AP_SSID was funtional, but change CONFIG_AP_PASSPHRASE in BCM943362WCD4 not work.
It's work, thank!
