I am using Avnets BCM4343W IOT starterkit, and want to add an extra desired state to the startup example "shadow".
Broadcom/WICED provide header files to libray functions like
mqtt_connection_event_cb
parse_json_shadow_status
wiced_JSON_parser_register_callback
Wiced_mqtt_connect
wiced_mqtt_publish
but no source code unfortunately, and not enough documentation or examples for me to add an extra desired state( a local threshold variable), that I can control from
AWS iot shadow update(delta state).
How can I publish so it will register as a desired state in AWS, and how can I parse the jason document and extract the value of a specific state "threshold"?
Can I use "parse_json_shadow_status" or is it custom made for the shadow example program?
What would it take to expand the BCM4343W board to collect data from 4 sensors, send data to AWS and be able to change "threshold" to each of them?
Can BCM4343W handle 4 concurrent treads, one for each sensor?
Thanks in advance.
AWS has provided one example of desired and reported as a scenario, its upto your design to have how many ever states.
Since its in json format, you can have multiple key value pairs in your json and have that parsed using the json parser library that we provide.
{ state :
{ desired : on ,
desired 2: off
{ reported : on ,
reported 2: off
and have this parsed in AWS dashboard as per your design requirement. Let us know if have specific example that you need help with
hth
vik86
