Community will be in read-only mode on 25th Sep for 10 hours. Click here for more details
mawu_4270096
50 replies posted 25 replies posted 10 replies posted
Hi:
   as we know, we can  compile some  codes which  we add  in a  project  by  some macros
for example. in the wiced studio SDK, there are many application project for  example mesh_level_client, mesh_onoff_server and so on !  however some codes are the common  codes  for example  device  provisioning codes  for  this  projects  !
I want  to add some codes for  the mesh_onoff_server project   during device  provisoining  ,but  I  don't   want to affect other projects
DheerajPK_41
You can define the macros in the makefile.mk or application.c file to provide access to libraries, and other C flags, etc.
Please make use of WICED documentation of API (API.html) to get list of available macros.
In mesh, common codes, eg: device provisioning, etc, are already handled by the mesh core codes.
Could you please explain more about your real requirement. What you meant by below sentence?
"I want  to add some codes for  the mesh_onoff_server project   during device  provisoining  ,but  I  don't   want to affect other projects"
DheerajPK_41
mawu_4270096
Hi  DheerajP_41:
      thank you for your timely reply !    I defined  a macro  and  add  the  corresponding  C flags  in the makefile.mk.  it works fine!
thanks!
Mandy
