How to Enable/Disable the Certification Authority Check
hiko_4316286
Level 4
Level 4
50 replies posted 25 replies posted 10 replies posted
The following question confirms how to set up the CA check, but how do you set up the switch to enable or disable the CA check?
<How to check the CA (Certification Authority)  >
Rakesh_BG
50 solutions authored 100 replies posted 100 sign-ins
Hi @hiko_4316286 ,
wiced_defaults.h
/* WICED TLS Options * /
#define WICED_TLS_DEFAULT_VERIFICATION (TLS_VERIFICATION_REQUIRED)
The above definition is enough for enabling TLS verification.
Rakesh B G
Rakesh_BG
Hi @hiko_4316286 ,
wiced_defaults.h
Rakesh B G
Thank you very much for your answer.
I understand that the CA check is performed by setting WICED_TLS_DEFAULT_VERIFICATION.
Incidentally, with the above setting, self-certification also works.
Am I right in thinking that the library determines the certificate and works fine (the correct private key is selected) regardless of whether the self-certificate or the third-party certificate is set?
Hi @hiko_4316286 ,
yes, your understanding is correct.
Rakesh B G
