How much EXTERNAL FLASH MEMORY capacity support for mcu STM32F205RG?8MByte support?
You can add your preferred Flash.
Please check and modify spi_flash_internal.h and spi_flash.c
in <WICED-SDK>/Wiced/Platform/common/drivers/spi_flash/.
Hi dmiya
    I can add 8MByte external flash memory if I modify the spi_flash* source code?
    Not need check mcu stm32f205rg support or not?
    Thanks!
Correct.
External flash can be used only as a storage.
We can not use it like internal flash. Program executes only on internal flash or RAM.
Hi dmiya,
     Thanks!
