Aug 24, 2019
07:19 PM
Aug 24, 2019
07:19 PM
Will the WICED device join the one with strongest RSSI?
If not, what is the logic to decide which AP to join?
Labels
WICED Studio
07:29 PM
Aug 28, 2019
07:29 PM
Which channel the 4 APs used ?
As my previous experience on 43362, It will try to join the first probe response from air. not according the signal !
Cause scan always start from channel 1, so always is connected to lower channel one.
We solved this by change the scan response callback , reply the scan result sort via signal strength !
Then join AP with specific BSSID, not SSID only.
But if you used another wifi chip maybe it used different algorithm to choice AP to join,
Which is handle by F/W of wifi chip!?
