Now I have a problem, do not know how to call the SDIO API interface.
What should I do if “platform“ is called and undefined
Here is my file:
- cyw943907aeval1f
- sdio
Here's an example of how platform_sdio_host_init() is defined and is available at
/43xxx_Wi-Fi/WICED/platform/MCU/BCM4390x/peripherals/platform_sdio_host.c
wiced_result_t platform_sdio_host_init( sdio_isr_callback_function_t client_check_isr_function )
glob_sd = sdioh_attach( NULL, client_check_isr_function, 0 );
if ( glob_sd == NULL )
return WICED_ERROR;
return WICED_SUCCESS;
The definition of glob_sd is available at /43xxx_Wi-Fi/WICED/platform/MCU/BCM4390x/peripherals/sdio_host/bcmsdstd.c
Hi
Could you try including 'platform_sdio.h' in the list of header files and check?
if this doesn't work, could you share your project, so that i could look into it and figure out whats wrong?
I have added the "Platform_sdio.h" header file to the project and is ready to use, but failed to initialize the SDIO,I used "platform_sdio_host_init" to initialize SDIO, but returned "WICED_ERROR".
Could you share your project so that we could look into it and figure out whats wrong?
This is my current code, still testing feasibility,I don't know what went wrong,Please help me modify it, thank you
#include "wiced.h"
#include "../../WICED/platform/MCU/BCM4390x/peripherals/platform_sdio.h"
void sdio_client_check_isr(void*);
uint32_t data[1024];
unsigned int leng = 0;
void application_start( )
/* Initialise the WICED device */
wiced_init();
if(platform_sdio_host_init(sdio_client_check_isr) != WICED_SUCCESS)
WPRINT_APP_INFO( ("sdio init error\n") );
}else
WPRINT_APP_INFO( ("sdio init successful\n") );
/* Client Interrupt handler */
void sdio_client_check_isr( void* user_data )
UNUSED_PARAMETER( user_data );
platform_sdio_host_disable_interrupt();
#include "wiced.h"
wiced_init();
}else
Hi
In the platform 'platform_sdio.h' file 'platform_sdio_host_init' is written as
extern wiced_result_t platform_sdio_host_init( sdio_isr_callback_function_t client_check_isr_function );
Thus, the function is just declared and is not defined.
You have to define the function first in your application and then use it. I tried it out in your code and got the log 'sdio init successful'
Can you show me your routine
I added these lines to your code and i get "sdio init error" or "sdio init successful" based on the functionality of the code.
if (your condition for success)
//your code
return WICED_ERROR;
You don't understand what I mean. I want to know how you define 'extern wiced_result_t platform_sdio_host_init(sdio_isr_callback_function_t client_check_isr_function' in 'platform_sdidi_sdidi_function';"This function can return success, or can you give me a routine about using SDIO for this development board CYW954904AEVAL1F? I am in urgent need of using SDIO now, but it has been unable to initialize and use, I hope you can give me a routine to learn. Thanks
return WICED_ERROR;
