I try to call
if (wwd_wifi_set_channel( WWD_STA_INTERFACE, 5 ) != WWD_SUCCESS) {
and I get a good return status. But when I enter monitor mode right afterwards:
wwd_wifi_set_raw_packet_processor( process_raw_packet );
wwd_wifi_enable_monitor_mode( );
It appears to give me packets from all channels as if it ignored the channel that I selected. Is it wrong to set the channel in this way, and is there a way to set it in monitor mode?
Roger
Hi Roger,
The function wwd_wifi_set_channel() is for setting the channel to which the WICED device needs to operate at. It is not meant for setting the channel for monitoring.
The monitor mode in the function wwd_wifi_enable_monitor_mode( ); is meant to scan all channels. You can see the usage of this function in WICED/internal/wiced_cooee.c. I'm afraid there is no way to enable a single channel on monitor mode.
Jaeyoung
Hi Roger,
Jaeyoung
