WiConnect is an easy to use API built on top of WICED available on all ACKme Networks modules
Having the latest firmware on your module is key to ensuring you are evaluating the latest feature set available in WiConnect.
The reference manual for WiConnect can be found here: http://wiconnect.ack.me
Upgrading firmware is very straight forward
  1. Open your terminal emulator (such as Teraterm)
  2. Configure the terminal emulator's serial port (115200, 8, n, 1)
  3. Configure the terminal emulator's terminal (CR+LF)
  4. Configure the network setting if not already done <setup cmd>
  5. Initiate the OTA update (Over the Air) <ota>
Full graphic available at <Click Here>
WICED Wi-Fi ForumsACKme Networks
Two great updates are on there way. The first adds gHm and special powersave modes, the second embraces a whole new platform.
Keep abreast by checking the following link: http://ack.me/Current_Firmware
ACKme Networks
WICED Wi-Fi Forums
