We will add an API for this in the next SDK release.
Until then, you can add the API manually as follows:
Add the following API function prototype to <WICED-SDK-2.2.1>/Wiced/WWD/include/wwd_wifi.h
/** Gets information about associated clients.
* @note Only applicable if softAP interface is up
* @param[out] pointer to a buffer that will be populated with a variable length structure defined by @ref wiced_maclist_t
* @param[in]  length of the buffer
* @return @ref wiced_result_t
extern wiced_result_t wiced_wifi_get_associated_client_list( void* client_list_buffer, uint16_t buffer_length );
Add the following API call to <WICED-SDK-2.2.1>/Wiced/WWD/internal/wwd_wifi.c
    wiced_buffer_t buffer;
    wiced_buffer_t response;
    uint32_t* data = (uint32_t*) wiced_get_ioctl_buffer( &buffer, buffer_length );
    CHECK_IOCTL_BUFFER( data );
    if ( wiced_send_ioctl( SDPCM_GET, WLC_GET_ASSOCLIST, buffer, &response, SDPCM_STA_INTERFACE ) == WICED_SUCCESS )
        memcpy( client_list_buffer, (void*) host_buffer_get_current_piece_data_pointer( response ), (size_t)MIN(host_buffer_get_current_piece_size(response), buffer_length) );
        host_buffer_release( response, WICED_NETWORK_RX );
        return WICED_SUCCESS;
    return WICED_ERROR;
FYI, the wiced_maclist_t structure looks like this ...
* Structure describing a list of associated softAP clients
typedef struct
uint32_t    count;         /**< Number of MAC addresses in the list    */
wiced_mac_t mac_list[1];   /**< Variable length array of MAC addresses */
} wiced_maclist_t;
