Okay this might be a dumb NOOB question, but I have never used Eclipse before and I am trying to figure out how to build a target that is release code only, no debug symbols, etc. I cannot seem to find how/where to do this. What is the trick? For example, calls to WPRINT_APP_INFO() should produce nothing on the UART if not in debug mode. Yet no matter what I do, it results in an error when building or those messages still appear. How to build/deploy release only?
SPI
You may suppress the WPRINT_APP_INFO() by commenting out the "#define WPRINT_ENABLE_APP_INFO" in \include\wiced_defaults.h. There are other WPRINT_ENABLE_<grpup>_INFO definitions that could be commented out as needed.
Hope it helps,
Seyhan
Hope it helps,
Seyhan
