Hello!
I want to implement <Get/Set INTERFERENCE_OVERRIDE_MODE> in my application.
About that, I found that there is a sample-code in mfg_test.
How can I use <INTERFERENCE_OVERRIDE_MODE> in my application?
In other words, I want to use the below function in my application.
static int wl_interfere_override(void *wl, cmd_t *cmd, char **argv);
Do I have to copy source-codes from mfg_test to my application?
Is there any easy way to use <INTERFERENCE_OVERRIDE_MODE>?
Thanks in advance.
(Self-answering)
I just solved the problem as below. (in SDK 2.4.0)
wiced_result_t wwd_wifi_set_interference_mode( uint32_t mode )
wiced_buffer_t buffer;
wiced_result_t retval;
uint32_t* data;
data = wiced_get_ioctl_buffer( &buffer, (uint16_t) 4 );
CHECK_IOCTL_BUFFER( data );
*data = (uint32_t) mode;
retval = wiced_send_ioctl( SDPCM_SET, WLC_SET_INTERFERENCE_MODE, buffer, 0, SDPCM_STA_INTERFACE );
wiced_assert("Failed to wwd_wifi_set_interference_mode\r\n", retval == WICED_SUCCESS);
return retval;
wiced_result_t wwd_wifi_get_interference_mode( uint32_t* mode )
wiced_buffer_t response;
wiced_result_t result;
result = wiced_send_ioctl(SDPCM_GET, WLC_GET_INTERFERENCE_MODE, buffer, &response, SDPCM_STA_INTERFACE);
if ( result != WICED_SUCCESS )
return WICED_ERROR;
memcpy( mode, host_buffer_get_current_piece_data_pointer( response ), sizeof(int32_t) );
host_buffer_release( response, WICED_NETWORK_RX );
return WICED_SUCCESS;
(Self-answering)
uint32_t* data;
return retval;
return WICED_ERROR;
