07:58 AM
Mar 25, 2016
07:58 AM
My application has its own SSL library which unfortunately conflicts with that of WICED SDK's BESL library. Is there a way I can disable or remove the WICED SSL library from the compilation path? I'm using a WICED 3.5.2 SDK.
Labels
SDK 3.x
- ssl
09:52 AM
Mar 25, 2016
09:52 AM
You will have to modify the makefile in the tools/makefiles directory. There is no default option to disable BESL
You could also remove the BESL directory and replace with your own but that is not recommended
09:52 AM
Mar 25, 2016
09:52 AM
