01:36 AM
Oct 06, 2015
01:36 AM
Hello Sir,
How about Max throughput of bcm943362 ?
have any project can do throughput test ?
I use sdk3.3.1 , modify the snip.udp_transmit and snip.udp_receive project
but I test throughput only 11k bytes.
I used wiced_rtos_register_timed_event(....) , setting UDP_MAX_DATA_LENGTH = 1024, UDP_TX_INTERVAL = 80ms
Can give me suggest ?
Thanks you Sir !!
Labels
- bcm943362
- throughput
07:27 AM
Oct 06, 2015
07:27 AM
Here's a couple of threads you will find helpful:
07:27 AM
Oct 06, 2015
07:27 AM
Oct 07, 2015
02:17 AM
Oct 07, 2015
02:17 AM
