Hi im new to psoc 6 and modus toolbox i tried running the sample code and selected the target board which in my case is psoc 6 wifi-bt . I've set up the aws account , created thing , attached policy to the certificate giving action as iot:* and resource as *. Also i've downloaded the certificates and according to the format included "\n" \ after each line for the certificate , set the endpoint in modus toolbox sample code to the endpoint of my aws , but it is not able to connect to aws and i dont know where lies the problem. i've also attached my output in teraterm , the problem is im not getting mqtt successfully connected message in my teraterm. So can anybody help me with this would be glad to hear from someone.
Looks like the MQTT connection is getting dropped. Can you retry by changing the certificates and using a different network and see if the connection goes through.
SoWa_4822066 As you see at GitHub - cypresssemiconductorco/mtb-example-anycloud-mqtt-client: This code example demonstrates con... in the targets supported by default are only PSoC 6 2M devices and hence you see this.
What you can do is try changing the IOT_THREAD_DEFAULT_STACK_SIZE at configs\iot_config.h to say 1024 or 2048 and see if the connection goes through.
thanks for the reply but still saying unknown packet ff received and error processing incoming data.
