ChMa_3922746
10 likes received 10 likes given 5 likes given
The OTA solution I am using right now is from the examples.  It requires that the device be put into AP mode.
My question is:  has anyone gotten OTA to work when the device is in STA mode (connected to an AP)?  If so, are there any examples around I could look at?
Thanks!
Aditi_B
500 replies posted 5 questions asked 250 replies posted
Unfortunately, we don't have any code implementation for OTA in STA mode. The examples that we have in the snip folder in WICED for OTA works in AP mode only. This function wiced_ota_server_start() uses the WICED_AP_INTERFACE to provide the HTML pages which connects to the device. So, as of now we don't have any examples for STA mode. But, we do have the flexibility to start the OTA server with different interface. You can definitely go ahead for the STA mode implementation.
Aditi
Aditi_B
Aditi
Ok, thank you.  I don't think it is a big change to change from AP to STA mode.  Ideally, I would like to copy the OTA code into my normal software so that the user can at least kick-off the OTA upgrade via the normal browser connection.
