We are developing firmware for Adafruit Wiced Feather https://www.adafruit.com/product/3056 to connect to AWS IOT. Everything works well, except when Identity is not used (private key & device certificate are not set) much like connecting to Server verification only. Wiced got hanged by ssl_write_certificate() by SSL binary Library probably writing to some NULL pointer. I know Identity should be set but we have no control over what user write, sdk should return an ERROR_TLS_ something instead.
VikramR_26
25 sign-ins 10 sign-ins 10 comments on KBA
Thnx for letting us know, we will fix this in the SDK
Thanks vik86
would you confirm this is an bug indeed, or it is just me ??
