HTTPS Server Allocates Memory for Context But Does Not Release It (CYW943907AEVAL1F)
ChMa_3922746
10 likes received 10 likes given 5 likes given
I was doing a bit of malloc debug since I saw memory increasing whenever new clients (Firefox web browser) connected to the WICED HTTPS server (TLS enabled).  I observed that the function http_server_deferred_connect_callback() allocates memory for each new client, but never frees the memory.  Over time the memory usage creeps up and up.
The function call that allocates the memory is context = malloc_named("https", sizeof(wiced_tls_context_t));
Can anyone think of a way to free up the memory after a period of time has expired (i.e., the client has not connected for some period of time)?  (Other than stopping and re-starting the server, that is.)
Thanks!
ZhengbaoZ_96 wrote:
Would you please try "free( http_server ); "  ?
Don't do that unless you use malloc to allocate memory for http_server.
Zhengbao_Zhang
250 sign-ins First comment on KBA 10 questions asked
#ifdef USE_HTTPS
        wiced_https_server_stop(http_server);
#else
        wiced_http_server_stop(http_server);
#endif
        wiced_rtos_deinit_semaphore(&aws_config_semaphore);
        /* Cleanup DNS server */
        wiced_dns_redirector_stop(&dns_redirector);
        /* Turn off AP */
        wiced_network_down( WICED_CONFIG_INTERFACE );
Thank you.   I tried it and found that free("http_server") crashes the processor.  On further investigation, I think that perhaps tls_context's build-up but some are never free'd.  After a while, and a few different clients connecting, I see multiple allocations which persist:
tls_init_context 228
  180
  180
  180
  180
  180
  308
  56
  308
  224
  56
  308
  224
  84
  84
  84
  839
Stopping the server & re-starting is not an option in my case.  I would expect the main server loop in "wiced_http_server_stop()" to clean up the hanging contexts, but maybe not...
hello :
We have tls_host_free function that is used for TLS context fress , would you please take a look at it if it can match your requests?
Right.  "free( http_server );" crashes the device.
In the file http_server.c, the function  http_server_deferred_connect_callback() contains the lines:
if ( socket->tls_context == NULL )
            if (context == NULL)
                HTTP_DEBUG((" L%d : %s() : Failed to allocate TLS context\r\n", __LINE__, __FUNCTION__));
                return WICED_OUT_OF_HEAP_SPACE;
            socket->context_malloced = WICED_TRUE;
Is there a way to search the sockets in an HTTPS server and then free the allocations?  Perhaps the sockets need to be removed first?
Thanks!
I stumbled across the function "wiced_http_disconnect_all_response_stream(server);" which appears to close the streams and free up the memory.  So, I think I have my answer.
This still leaves the observation that the server does not, by default, close streams that haven't been used for a while (or orphaned?).  Hence, memory allocation keeps building and building over time.
