We are just getting started with the Wiced SDK and are trying to understand how to use the HTTP server functionality.  While there are numerous demos, the use case contexts are not clear.  The simple case of displaying a static web page is self evident, but we need to have a web page where there is information displayed in editable fields, allow the user to change the data, and submit the page back so we can react to the changes.
There is a config_http_content module that seems close to what we want to do, but it is not clear how some of the elements in the http page are accessed or processed.
I am searching for documentation that might describe the api and processing model for this sub component of the SDK.   Any pointers or suggestions for how to learn the conceptual model without having to grind through chanding and testingwith the examples?
Hi Brad,
You may want to explore the latest SDK which supports AWS.
The SDK can be downloaded here.
Let us know, if it helps you.
AB
