Get a software for radio certification ?
badic_1722426
Hi all,
We try to certicate our product by an EMC laboratory and this laboratory asks to genarate this radio mode :
We use the USI module and to realize the software, I've took the snip.console example compiled with the WL commands, to generate the different mode with the following command :
But each time, I execute the pkteng_start command, I've the result  “wl unsupported”.
So my question is how to realize the demand of the laboratory ?
Thank you for your help.
Baptiste
Which version  windows you run the wl43362.exe !
Basic the wlXXXX.exe buit-in SDK is build for Win32! We try it under WinXP is work!
But if you run wlXXXX.exe under Win64 environment will run-into some problem!
maybe you could find one PC run WinXP to check it could pass your WiFi test
or  re-build the wlXXXX under your Windows platform!
