my os is windows10 and develope environment is WICED Studio 4.1.1 IDE.
I want to create shadow example DCT Image. (refer to "WICED-AN800-R-Factory-Programming.pdf")
First, I downloaded this -> (https://github.com/wlljk2002/bcm-wiced-sdk/tree/master/apps/demo/temp_control)
and copy factory_reset_dct.c file , mfg folder (included files also)
Second, I modified factory_reset_dct.c and mfg/0001.txt
**factory_reset_dct.c (I changed the contents to this code.)**
static const factory_reset_dct_t factory_reset_dct =
/* Security Credentials for Config Section _______________________________________*/
.Platform.security_credentials.certificate = _DYNAMIC_CERTIFICATE_STORE,
.Platform.security_credentials.private_key = _DYNAMIC_PRIVATE_KEY_STORE,
**0001.txt***(I changed the contents to this code.Omit the contents of the security keys)
CERTIFICATE_STORE="-----BEGIN CERTIFICATE-----\r\n"\
"-----END CERTIFICATE-----\r\n"\
"\0"\
"\0"
PRIVATE_KEY_STORE="-----BEGIN CERTIFICATE-----\r\n"\
"\0"\
"\0"
Third, I input Windows cmd shell command to build shadow application
> .\make demo.aws_iot.shadow-BCM943907WCD2 factory_reset_dct apps/demo/aws_iot/shadow/mfg/0001.txt
(This is done after moving to the path where 'make' file exists.)
But I got the error message.
MAKEFILE MAKECMDGOALS=demo.aws_iot.shadow-BCM943907WCD2 factory_reset_dct apps/demo/aws_iot/shadow/mfg/0001.txt OTA2_SUPPORT is disabled
Makefile:322: warning: overriding recipe for target 'demo.aws_iot.shadow-BCM943907WCD2'
Makefile:288: warning: ignoring old recipe for target 'demo.aws_iot.shadow-BCM943907WCD2'
Makefile:322: warning: overriding recipe for target 'apps/demo/aws_iot/shadow/mfg/0001.txt'
Makefile:288: warning: ignoring old recipe for target 'apps/demo/aws_iot/shadow/mfg/0001.txt'
Makefile:360: warning: overriding recipe for target 'factory_reset_dct'
Makefile:322: warning: ignoring old recipe for target 'factory_reset_dct'
make: *** No rule to make target 'wiced_factory_reset.mk', needed by 'factory_reset_dct'. Stop.
and I found wiced_factory_reset.mk file , but this file is not exist
Please help me figure out what's wrong.
DCT
Manufacturing and Test
I received an answer via cypress.
At present WICED Studio 4.1.1 is not support R-factory-Programming process.
(R-factory-Programming.pdf donwload link: https://community.cypress.com/docs/DOC-3954)
it wiil support to again at Wiced Stduio 4.2.
Hello Hanbeom-nim,
The temp_control app you linked to is based on an older version of the SDK, 3.1.0. This will not work if your project is based on WICED Studio 4.1.1.
Please try with the attached version of factory_reset_dct.c included in the temp_control app folder and let us know if this works for you. Also, please try the original temp_control app attached here to verify that it works on your board before applying your changes.
Jaeyoung
thanks your answer .
I downloaded attached file, and entered a command line.(no applying my changes)
but same error message was printed.
command >>> .\make snip.temp_control-BCM943907WCD2 factory_reset_dct apps/snip/temp_control/mfg/0001.txt
MAKEFILE MAKECMDGOALS=snip.temp_control-BCM943907WCD2 factory_reset_dct apps/snip/temp_control/mfg/0001.txt OTA2_SUPPORT is disabled
Makefile:322: warning: overriding recipe for target 'snip.temp_control-BCM943907WCD2'
Makefile:288: warning: ignoring old recipe for target 'snip.temp_control-BCM943907WCD2'
Makefile:322: warning: overriding recipe for target 'apps/snip/temp_control/mfg/0001.txt'
Makefile:288: warning: ignoring old recipe for target 'apps/snip/temp_control/mfg/0001.txt'
Hello Hanbeom,
Thank you for replying and keeping the thread updated. We assure you factory programming will be supported in Studio 4.2. Thank you for your patience.
Best,
Jaeyoung
Note that WICED Studio 5.0 will be the next release.
We should be releasing it to the community in early May.
May I get early access of sdk-5.0?
Check you inbox.
Hi Mifo,
Can I also get early access to SDK5.0? I'm working on the DCT part and looking for an easier way to flash firmware on 30 devices.
Josh
There is one question.
Is there any other way to mass produce and flash DCT images individually as in r-programming.pdf? (In version 4.1)
Is there any other way in the current version?
