when I first refer to CYW943907AEVAL1F_Evaluation_Kit_User_Guide-UserManual-v01 to building the example,there have two ERROR.
1.'resources_firmware_DIR_43909_DIR_43909B0_bin' undeclared (first use in this function)
2.'resources_firmware_DIR_43909_DIR_43909B0_clm_blob' undeclared (first use in this function)
I hope you can help me to solve this problem.
remark: I have not connected the machine to use, just building.
Hi:
Thanks for your reply.
We have found that it is the problem of encryption software.After we shut down the encryption software.The program is ready to run.
Hello:
Would you please share your command flow? I can have a try on my side with the same step.
Hi:
Thanks for sharing the experience
