I am in the process of incorporating Enterprise Wi-Fi into the application based upon the "join_ent" demo app.
I normally have an HTTPS server running on the WICED device. When connected to Personal Wi-Fi, everything is fine. When the WICED device connects to Enterprise Wi-Fi (via a freeradius server) configured for TTLS, the WICED device is authenticated by the Radius server and connects properly. It can ping, etc. Looks good.
However, the Enterprise Wi-Fi appears to also "kill" the TLS connectivity to the HTTPS server somehow. I can run an HTTP server (no TLS) with no problem.
Has anyone got both working at the same time?
Thanks!
Understood, thank you. In summary, then, the function besl_supplicant_init calls wiced_tls_init_root_ca_certificates which, in turn, mandates client authentication if conn_info.trusted_ca_certificates is specified.
Case closed!
