Hi There,
I am having a bit of a problem which I am pretty sure is my fault 🙂
I am trying to implement FW upgrade in my application, much like the OTA application, but using standard HTTP server. I am trying to send data chunk via POST method.
I eventually end up in my dynamic content handler. The wiced_http_message_body_t * http_data shows:
ttp_data->message_data_length = 0x00000000
http_data->total_message_data_remaining = 0x00000400
http_data->chunked_transfer = 0x00000000
I then  simply allocate a buffer of size equal to http_data->total_message_data_remaining, read data by doing:
if (wiced_tcp_stream_read(stream, pBuf, http_data->total_message_data_remaining, 2000) != WICED_SUCCESS) {
     printf("wiced_tcp_stream_read() failed\n");
free the buffer and returns.
Client get the OK and sends second data chunk but my device is actually stuck after returning from my handler and this until watchdog resets.
I am pretty sure that I am not doing something right, or probably forgetting to do something. Is wiced_tcp_stream_read() the correct way to get data from a POST ? Is there anything else I need to do after calling wiced_tcp_stream_read() ? I have tried to look at the OTA server sources but it is much different and did not find what I was looking for.
Oh, and yes I am not HTTP protocol expert 😉
Thanks much.
Anybody can help me getting data from POST  ?
I am still having same issue with 3.1.2
Feels real nice having a conversation with myself 🙂
I traced the problem to the HTTP server:
http_server_parse_packet() line 444 with the call of wiced_http_server_set_http_message_body_type_for_socket()
POST is viewed as a transaction with data split across packet, dynamic content API get that data using wiced_tcp_stream_read(), when it returns, server tries to handle second part of that transaction, which does not exist, HTTP server hangs.
I worked around this by not calling wiced_http_server_set_http_message_body_type_for_socket() if the request is a "POST", it seems to be "good enough" for me, but I would really like to get advice from a network expert.
Guillaume
Did you try it with ThreadX+NetX?
Because FreeRTOS+LwIP seems to have similar problem like you
But ThreadX +Lwip works fine to me
FreeRtos and Lwip seems to close socket .
I am not sure.
I tested with SDK 1.3.1
Tks
I'm using ThreadX and NetX duo, I don't think it is a OS/Stack issue, I is most probably a HTTP server problem.
Can you create a new discussion if this is still an issue in 3.1.2?
This is still an issue with released SDK, that can be address with the fix I described. I doubt duplicating post in the forum is the best way to address this, it might confuse people.
Hi Guys,
Did you notice how strstr function is used in HTTP server, i.e:
result = wiced_http_server_get_packet_data( socket, packet, &request_string, &request_length );
if ( strstr( request_string, HTTP_HEADER_CLOSE ) != NULL )
The problem is request_string is non-null terminated.
Oleg
