I want to connect CYW45455 to STM32F103, I download Wiced Studio and create some make target for testing. But none of them success.
Target: snip.scan-CYW943455EVB_02-ThreadX-NetX_Duo-SDIO
Result: WICED/RTOS/ThreadX/ThreadX.mk:84: *** No ThreadX port for architecture. Stop.
Target: snip.scan-CYW943455EVB_02-FreeRTOS-LwIP-SDIO
Result: make[1]: *** No rule to make target `WICED/WWD/internal/chips/43455/wwd_ap.c', needed by `build/snip.scan-CYW943455EVB_02-FreeRTOS-LwIP-SDIO/Modules/./WICED/WWD/internal/chips/43455/wwd_ap.o'. Stop.
We are pushing for support of the broad market version of the 43455 within the next release of WICED. I don't have an exact date at this point, but I expect it to be released in very early 2019.
FYI, I download Wiced Studio 6.2.1
Hello Jacky,
Can you check if you have 43455 directory in WICED at this location: Wiced-SDK\WICED\WWD\internal\chips?
In case you dont have this directory, kindly uninstall, delete all the files related to WICED SDK 6.2 and try a fresh installation.
I'm using ubuntu linux 16.04. After install the studio, no 43455 in the chips directory:
jacky@pc:~$ ls Documents/WICED-Studio-6.2/43xxx_Wi-Fi/WICED/WWD/internal/chips/
4334x 43362 4343x 4390x
The windows version of Wiced Studio is the same too
Please uninstall, delete all the files related to WICED SDK 6.2 and try a fresh installation.
It don't work. I have not install WICED Studio before.
If your statement is true, you just prove the installer is buggy.
Update:
I think the 43455 support in MFI version WICED SDK 6.2.1 only.
include BT F/W, WiFi F/W, and misc supported files under WICED/WWD/internal/chips/43455/
chip_constants.h
wwd_ap.c
wwd_chip_specific_functions.c
The 43455 platform is included within WICED Studio 6.2.1 broad market as shown below:
The point is:
43xxx_Wi-Fi/platforms/CYW943455EVB_02/ exist, but 43xxx_Wi-Fi/WICED/WWD/internal/chips/43455 does not exist.
just installed WICED-Studio-6.2.1.2-IDE-Installer.zip
while \WICED-Studio-6.2\43xxx_Wi-Fi\platforms folder do have content for CYW943455
but \WICED-Studio-6.2\43xxx_Wi-Fi\resources\firmware folder do not have the necessary firmware files for 43455.
where can we get the firmware files for 43455 ?
thanks
i browsed some older wiced versions and noticed that 43455 FW is available in Wiced 5.2
hope it helps to all.
The CYW43455 will be supported officially (EVK/Firmware/New Platform Files) in Modus 1.0, which is slated for release late October/Early November.
Any update? I'm waiting for the new release.
Thanks for your help.
But as I asid before, there are many known problems in current sdk.
Delay release is not a good option. (Most existing users need bug fixes for current sdk)
Anyway, just a suggestion, you know the whole status better than me.
The next WICED release will be an update to the current 6.2.1 rev that has been available for some time now.
