If yes, is there any example code available for mutual authentication?
If no, do you have plan to support it?
Hi axel.lin,
Yes. We have support of mutual authentication for both client and server. you can refer snip/https_server in 3.7.0 latest SDK.
There are two APIs needed to enable mutual authentication.
wiced_tls_init_identity( &tls_identity, dct_security->private_key, strlen( dct_security->private_key ), (uint8_t*) dct_security->certificate, strlen( dct_security->certificate ) );
-> This API will load server certificate and server key which is already stored in DCT.
wiced_tls_init_root_ca_certificates( httpbin_root_ca_certificate, strlen(httpbin_root_ca_certificate) );
-> You also need to load root certificate which will be used to verify client certificate.
Vikas
I have the same question. Specifically when the WICED device is acting as the server.
In the snip/https_server example code, I see that an 'identity' is passed to the wiced_https_server_start() call which contains the device certificate programmed into the DCT. It seems to lack, however, a means of specifying the client credentials (i.e. the client's root CA) when mutual authentication is desired.
Hi axel.lin,
Vikas
