I am using the CY8CKIT-062-WiFi-BT kit and WICED studio 6.2.
I am trying to debug the Scan snip. My make target is "snip.scan-CY8CKIT_062-debug download_apps download".
The board is in CMSIS-DAP mode.
However when I run the windows debug I get the following message.
I am just starting to learn WICED so bear with me if this is a noob question.
ispn:39620:1:0
l1:314:1:0
Wifi+Bluetooth
- debug
1. In the Debug configuration add the following commands in Halt parameter in Startup tab
monitor targets psoc6.cpu.cm4
monitor psoc6 reset_halt sysresetreq
monitor sleep 500
2. Untick the Load image
3. Go to Runtime Options
Tick the Set Breakpoint at: application_start
Tick the Resume tab
Create a debug make target and launch the debugger now. Attached is the screenshot of debug configuration working in SDK 6.2.1
Yes I completed those steps but the error persists.
I have been able to reproduce the issue and we are internally tracking the same. I will update the thread once the issue is resolved.
I have just come across the same error when trying to debug the uguitest2 app on the CY8CKIT_062. I followed the instructions in "Debugging the BCM943362WCD4_EVB". My make target is "ww101.04.07_uguitest2-CY8CKIT_062-debug download. After than, I run 433xx_Wi-Fi_Debug_Windows. The error says:
Error in final launch sequence
Failed to execute MI command:
load C:\\Users\\john\\Documents\\WICED-Studio-6.2\\43xxx_Wi-Fi\\build\\eclipse_debug\\last_built.elf
Error message from debugger back end:
Error erasing flash with vFlashErase packet
monitor sleep 500
Tick the Resume tab
