Wi-Fi Combo Forum Discussions
I modified the SDK to be able to download code with Stlink2 : it works fine.
However, impossible to debug : put breakpoint, doing step by step debug. Impossible to go to the entry point.
Platform used :  BCM943362WCD4
BR
Lionel
Try to run your st-linkv2 as a debug server on a certain TCP/IP port. In eclipse set the debug configuration to enable remote target debugging and set the port number to the st-linkv2 debug port.
