MaSk_4726556
First like given
Hi all -- new to Wiced.
I am trying to do something simple -- I want to change the color scheme of the IDE to a dark mode. I know that eclipse supports it -- I can see the themes in the Eclipse marketspace. Problem is that when I try to install them the install always fails because some dependency is missing -- it doesn't really matter which theme it is - they all fail.
Any pointers?
Matt
YashM
First question asked 250 sign-ins 100 replies posted
Hi Matt,
The default way to change your WICED IDE theme to dark mode is...
In the menu bar, head to Window -> Preferences -> General -> Appearance, there you will find the Dark mode under Theme menu.
I am attaching the screen shots for your reference
Regarding the Eclipse marketspace, even I am facing the same issue (not sure why) and will get back to you once it is solved, but for a time being you can use the above solution.
Thanks and regards
Yash
YashM
Hi Matt,
Thanks and regards
Yash
Thanks! Pending the marketplace issue, this has helped. Not sure why I never saw it -- doh.
Matt
YashM
Hi Matt,
The update is, WICED studio does not support Eclipse marketplace.
Yash
